AP1832 keep rebooting
owen2
HI People,
Need help here.
My AP 1832 just keeps rebooting out of a sudden.
Led indicator going from blinking green > red> amber.
and it just repeats and repeats.
run command show logging.
*sntpReceiveTask: Jun 21 16:59:57.360: %DNS-3-GETADDRINFO_SUCCESS: dns_query.c:243 getaddrinfo succeeded
*fp_main_task: Jun 21 16:59:52.404: %CLIWEB-3-INIT_FAILED: cli_web_util.c:780 Unable to initialize. Reason: Unable to set the https support to dtl..
*fp_main_task: Jun 21 16:59:52.401: %CLIWEB-3-INIT_FAILED: cli_web_util.c:761 Unable to initialize. Reason: Unable to set the secure webauth mode to dtl..
*ethoipSocketTask: Jun 21 16:59:52.355: %ETHOIP-2-SOCKET_OPEN_ERROR: ethoip.c:205 Unable to open Ethernet-over-IP socket
*fp_main_task: Jun 21 16:59:52.269: %DC-3-DC_DB_INIT_FAIL: dc_init.c:1243 Device Classifier Profile Update Refresh Failed.
*capwapPingSocketTask: Jun 21 16:59:51.788: %CAPWAPPING-2-SOCKET_OPEN_ERROR: capwapping_shim_wlc.c:418 Unable to open Mobility Data Ping socket
*mmListen: Jun 21 16:59:48.530: %MM-3-SOCK_OPER_FAILED: mm_listen.c:12016 Failed to set socket option IP_MULTICAST_TTL with errno=9.
*mmListen: Jun 21 16:59:48.530: %MM-3-SOCK_OPER_FAILED: mm_listen.c:12008 Failed to set socket option IPV6_MULTICAST_HOPS with errno=9.
*mmListen: Jun 21 16:59:48.529: %MM-3-SOCK_OPER_FAILED: mm_listen.c:12532 Failed to set socket option IPV6_TCLASS with errno=92.
*fp_main_task: Jun 21 16:59:46.121: %CNFGR-3-INV_COMP_ID: cnfgr.c:3444 Invalid Component Id : Unrecognized (45) in cfgConfiguratorInit.
*spamSocketTask: Jun 21 16:59:46.092: %LWAPP-2-SOCK_ERR: spam_net.c:1997 Error opening LWAPP socket
When I run debug, below is the output.
*spamApTask0: Jun 21 17:33:14.005: a0:f8:49:88:6e:40 Discovery Request from 192.168.1.194:5272
*spamApTask0: Jun 21 17:33:14.005: a0:f8:49:88:6e:40 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50, MaxLicense=50 joined Aps =0
*spamApTask0: Jun 21 17:33:14.005: a0:f8:49:88:6e:40 apType = 77 apModel:
*spamApTask0: Jun 21 17:33:14.006: a0:f8:49:88:6e:40 Discovery Response sent to 192.168.1.194:5272
Please Help..
