AP2802I Web Interface
derarneson
Frequent Visitor
Frequent Visitor
I have multiple controllers with 2802I access points associated to them and in some locations you can access the AP2802I directly via HTTP giving you admin control to the access point but in other locations you cannot. I want to disable the web interface on all my 2802I access points.
I have looked over the settings of the controllers and I have not found anything that would disable the web interface and there is nothing in the web interface of the access point itself to disable HTTP. As I write this I am looking for a CLI option but I would much prefer if there was a setting on the controller I could change that would affect all connected access points rather than having to go through nearly 200 individual access points.
All my controllers/APs are currently on software version 8.5.135.0
Thanks for any assistance.
Rosa Ladera
Level 4
Level 4
Hi?
Have you tried a acl controll list denying 80/443 ports?
Rosa Ladera
Level 4
Level 4
Hi?
patoberli
I think that's a bug in your used software. It should be fixed in the release after 8.5.140.0, probably in 8.5.150.0. There is a beta version out, which contains the fix.
