Wildcard certificate for web auth on WLC
carl_townshend
Hi All
I am trying to upload a wildcard certificate on my WLC running version 8.0.110.0
I have a pem file with the root, intermediate and end entity in one cert.
When I upload it, it just comes up with file transfer failed.
Any idea why this is?
Are wildcard certs supported on the WLC?
Cheers
Hi Carl,
Run the command debug transfer all enable to check the reason for failure. There is no limitation kind of on the web-auth certificate. Ref this link Web-Auth Certificate Installation and Troubleshoot
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Hi There
It still seems to be failing with the following message,
*TransferTask: Apr 15 10:40:57.325: RESULT_STRING: TFTP receive complete... Installing Certificate.
*TransferTask: Apr 15 10:40:57.325: RESULT_CODE:13
*TransferTask: Apr 15 10:41:01.340: Adding cert (7406 bytes) with certificate key password.
*TransferTask: Apr 15 10:41:01.377: sshpmCheckCert: Verification return code: 1
*TransferTask: Apr 15 10:41:01.377: Verification result text: ok
*TransferTask: Apr 15 10:41:01.387: sshpmAddWebauthCert: Extracting private key from webauth cert and using bundled pkcs12 password.
*TransferTask: Apr 15 10:41:01.394: sshpmDecodePrivateKey: private key decode failed...
*TransferTask: Apr 15 10:41:01.394: sshpmAddWebauthCert: key extraction failed.
*TransferTask: Apr 15 10:41:01.394: RESULT_STRING: Error installing certificate.
*TransferTask: Apr 15 10:41:01.394: RESULT_CODE:12
Any ideas ?
Have you created the CSR with a private key? If not, do not include a private key inside the certificate.
Also have another read at this document: https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
You should also upgrade to the latest 8.0 WLC release, you use a VERY old one, with various known security issues and many bugs.
