AP802 (C877VA-W modular AP) and multiple broadcast SSID's
Hamish Marson
Hi.
I now know that in order to have an ssid visible (broadcast) you need to set it as guest-mode in the dot11 config for the ssid. But how do i broadcast more than one ssid? When i try the AP disables the second and subsequent ssid and says only 1 ssid may be guest-mode...
H
Stephen Rodriguez
You need to add the commands
Dot11 mbssid globally. Then under the main radio interface mbssid.
Under the SSID mbssid guest-mode
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Steve
HTH,
Steve
Thanks. I will try that tonite
When I type "dot11 messed" globally, I get:
ap(config)#dot11 mbssid
Dot11Radio0: MBSSID is not supported on this radio - multiple MAC addresses not found.
Dot11Radio1: MBSSID is not supported on this radio - multiple MAC addresses not found.
Error: None of the Radio Interfaces can currently support MBSSID.
What, now?
