applying proxy in WLAN controller
TECH-JEFF
Level 4
Level 4
Hi, we have a wireless controller 2500 series and 10 AP's inside the controller's GUI, I can't find the section where I can point the controller in a proxy server so that it hasa certain security filters especially for users browsing the internet.
Jeff
Jefferson Co
Stephen Rodriguez
You don't configure the controller to have a proxy server, it's not going to browse the Internet.
For the clients you could return the proxy settings via DHCP option? Or just tell your proxy to always listen to the wireless VLAN, so long as it is in the path to the internet.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Thanks Stephen, I did direct the users using our DHCP server, in DHCP configure server options to use a wpad, then they're no running on a proxy.
Jeff
Jefferson Co
Saurav Lodh
Level 11
Level 11
you cannot configure such web proxies or web filters for users
