APs Using Unassigned Channels
Jesutofunmi O
Level 6
Level 6
I have set up a Cisco WLC 9800 with C9130AXI-E Access Points. I created an RF profile that only has the last 4 non-DFS channel (153-165). However, the AP never uses the assigned channels in the RRM-DCA config. It selects and uses random channels that are not defined in the RF policy/RF tag. I have checked and confirmed that the AP is indeed using the assigned RF tag which has the RF profile where I set my preferred channels. Does anyone, by any chance, know the cause of this?
The controller firmware is 17.15.5. See attached screenshots.
JT
2 Accepted Solutions
Mark Elsen
  - @Jesutofunmi O                Check if these channels are allowed in your country using https://apchannels.cisco.com/
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
This was a very valid answer and perhaps the solution; only that I couldn't find my AP model on there - C9130AXI-E
Thanks to everyone who helped with this. The issue persisted after I changed the the Global RRM Channel Assignment Mode to Auto (and clearly, it should have been set to Auto, not off). However, the issue persisted because the APs were not using the global RRM. I had assigned a custom RF profile to the AP where I specified the channels I wanted (153-165).
I noticed that when manually assigning channels, the WLC did not allow the manual assignment of the last 4 channels (153-165), which were the channels I had attempted using in the DCA settings. The moment I switched to 4 other channels (44-56), the connected clients moved to it. It then made sense why the WLC assigned the first channel (36) to the AP at first.
In many European countries, the usable 5 GHz channels are primarily: 36–64 (UNII-1 / UNII-2A) and 100–140 (UNII-2C / DFS)
Channels 149–165 are generally not permitted in most ETSI countries, except the UK.
The AP I have is a -E domain AP, channels 153, 157, 161, and therefore has those channels disabled.
Many thanks again to everyone who helped with this.
14 Replies 14
aleabrahao
Meraki Community All-Star
In your screenshot, the channel width is set to "Best."
When DCA is permitted to choose the channel width dynamically, the AP can form 40/80 MHz channels from the channels you have authorized. The displayed operating channel may sometimes appear different from the individual 20 MHz channels you selected. Cisco's DCA algorithm takes into account both channel assignment and channel width.
I'd change the RF profile to a fixed 20 MHz width and see whether the AP remains on 149/153/157/161/165.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
I had manually set the channel width to 20MHz and assigned the last 4 channels but that didn't fix it
Post the complete output to the following WLC commands:
sh ap dot11 5ghz channel
sh ap dot11 5ghz summary
Hi Leo,
Please find attached.
JT
@Jesutofunmi O wrote:
Channel Assignment Mode                    : OFF​
Uhhhh wut?
OFF means "Turns off DCA and sets all AP radios to the first channel of the band, which is the default value. If you choose this option, you must manually assign channels on all radios."
Ideal setting is Automatic.
Reference:  Configure 802.11 RRM parameters
Thanks Leo. I had spotted it too and changed it to Auto.
JT
Mark Elsen
  M.
For future reference you can see the available channels at a glance with show wireless country channels:
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
balaji.bandi
May be worth trying fixed to 20 - best working for long working my profile
BB
I had tried that before changing it to auto
what was the outcome can you show us any output or logs to understand
show ap dot11 24ghz summary / show ap dot11 5ghz summary
BB
Hi Balaji, pls find attached.
Looks like you're already in solution by configuring manually, which fixes the issue.
BB
