04-28-2014 01:38 PM - edited 07-05-2021 12:44 AM
Welcome to this Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about configuring and client interoperability of wireless 802.11ac with Richard Hamby and Yilin Weng.
The ever-growing demand for faster wireless connectivity brings us to the 802.11ac standard. Cisco’s new portfolio of 802.11ac-capable access points delivers new features to the enterprise. The current range of unified and converged wireless controllers supports 802.11ac and uses the overall Cisco strategy to deliver performance and management to your network.
For this discussion, Richard Hamby and Yilin Weng will help to demystify some of the concepts and deployment considerations required to make your 802.11ac environment the best it can be. They will also answer your questions related to specifics of the 11ac standard, client interop, configuration, troubleshooting, and deployment considerations for your wireless network.
Richard Hamby is a technical support engineer in the Cisco Technical Assistance Center in Richardson, Texas. He is an expert in wireless products, including the Cisco Unified Wireless Network and the new Unified Access Wireless products. Prior to his current position, Richard was a customer support engineer with the authentication-authorization-accounting team supporting Cisco identity management solutions.
Yilin Weng is a technical support engineer in the Cisco Technical Assistance Center in Richardson, Texas. He is an expert in the Cisco Unified Wireless Network and Next-Generation Wiring Closet (NGWC). Yilin has been working for Cisco since 2011 and holds CCIE certification 39885 in wireless.
Remember to use the rating system to let Richard and Yilin know if you have received an adequate response.
Because of the volume expected during this event, our experts might not be able to answer every question. Remember that you can continue the conversation in the Wireless Mobility community, under subcommunity Security and Network Management, shortly after the event. This event lasts through May 9, 2014. Visit this forum often to view responses to your questions and the questions of other Cisco Support Community members.
Solved! Go to Solution.
05-07-2014 09:47 AM
Hi Henry,
This is probably the most frequent topic and there are a number of typical root causes. Here are some of the most common:
• Client wireless device drivers
While 802.11ac-capable client devices and access points have been on the market for the last 12-18 months or so, the fact is it's still an evolving technology and plenty of interoperability issues have been discovered and addressed during its adoption. Too, early versions may not yet have supported many features defined in the standard. Check with your vendor and install current versions of the drivers as a first step.
• Interoperability issues for non-11ac clients
11ac-capable APs advertise new information elements (IEs) in their beacon/probe responses that did not exist a couple of years ago. And from an RF perspective, things look a little strange in the air compared to when that adapter or driver was state-of-art. While the device may not be 11ac-capable, it needs to be able to interoperate. The 802.11ac standard is written to be backwards compatible with b/g/a/n devices, but older drivers may not have been written or tested with 11ac in mind. Again, consider starting with a driver upgrade as first troubleshooting step.
•Adapter Capabilities
802.11ac promises to deliver raw wireless data rates up to 1300 Mbp/s – and it can with the right hardware under the right conditions. But the proper access point and client adapter are required – just because a device is 802.1ac-capable doesn’t mean it is able to fully exploit it. To achieve that speed, the client adapter and the access point must be capable of supporting 80MHz-wide 4-channel bonds, 3 spatial streams, and a guard interval of 400ns. Most USB 11ac client adapters and integrated chipsets in mobile devices on the market are 1SS or 2SS, therefore the max possible rates they can achieve will be lower. The data rates supported by each AP are in their respective Data Sheets, and the Tables are useful to describe what's possible for each # SS, GI, channel width, etc. Below is the link to the AP 3700 data sheet for reference.
So for example, take a 1SS-capable 11ac device with 80MHz channel. The maximum possible 11ac DTR for that device is 433.3Mb/s. Many Apple MacBook Air and Pro models have a Broadcom 3SS-capable card so they are the most common we see in the field capable of top DTRs. Check the specs on your adapter, and if purchasing a new one compare the capabilities.
• Configuration
802.11ac (like 11n) requires the WLAN to have AES encryption (or Open) and WMM. Also, 4 channels must be available and assigned to each AP for the 80MHz bond to achieve highest rates. If using the WLC, check under DCA and verify 80MHz channel width is enabled. If any one of these is not met then 11ac will not work. Too, check the driver configuration of the client adapter and verify it’s set properly for 11ac.
One other common quirk that comes up is how the WLC reports client 11ac rates. It does not report the clients' rate in channel-width qualified terms, only an MCS Index and # of SS (refer to Yilin's earlier post). So if you see M9 3SS (for example), that could mean 288.9, 600, or 1300 depnding on the channel-width configuration of the AP. For long GI rates, we list the actual DTR value the client is using. So when reading client details, keep in mind what the channel width is of the AP. I may file an enhancement request for this so it's clearer.
• RF Conditions
All typical WiFi caveats apply for 802.11ac just like legacy standards. Wireless is a half-duplex, shared medium environment so think ‘Hub’ (not switch) when considering throughput math. Each addition of a new associated device divides the aggregate available bandwidth of the AP. Even under the best of RF conditions, WiFi is lossy. 802.11 frame loss over-the-air occurs regularly and can vary greatly depending on hardware (client and AP), interference, and distance from the AP just to name a few. The impact this loss can have on protocol packet data performance also varies depending on the type of stream, IP stack, protocal, etc. Realized data transfer rates will be lower than the raw wireless data rate by an appreciable margin.
Also – until a few years ago when MIMO and 11n came into play, multipath was the devil. Much of our own documentation still discusses ‘multipath mitigation’ in evil terms. But to achieve 11n and 11ac rates, multipath is essential. This requirement presents special challenges especially in outdoor environments where there are no convenient cubes/windows/floors/ceilings to induce MP. For environments where MP may not be intrinsic, consider the use of external antennae with cross-polarized elements which can help induce it.
• Software Bugs
If you are not running the current versions of AP or controller code and are experiencing an issue, check the Release Notes of latest images to see if any issues have been addressed. There have been a few 11ac-specific fixes published since 7.5/7.6 first released so consider current code (7.6.110.0 as of this writing). You can also check the Bug Toolkit on cisco.com for more up-to-date information or call TAC for assistance.
04-28-2014 07:54 PM
Hi Guys,
Thanks for having this conversation.
Is there any CIsco 802.11ac deployment guide available us to refer ? I am in a campus environment & looking for gradual 802.11ac deployment within next 12 months.
Rasika
04-29-2014 11:56 AM
Hi Rasika,
Here are some of the links to materials that are available, none are specifically 'planning' guides so let me know if there are any specific details you'd like to discuss as well:
802.11ac Solution Site
http://www.cisco.com/c/en/us/solutions/enterprise-networks/802-11ac-solution/index.html
802.11ac - The Fifth Generation of Wi-Fi Technical White Paper White Paper
Farpoint White Paper
802.11ac Meraki Migration Guide
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_80211ac_migration.pdf
AP 3700 Deployment Guide (Good general 11ac info as well)
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/7-6/Cisco_Aironet_3700AP.html
For specific configuration information, here are some links to the deploymen guides as well:
Unified (WLC 2500/5500/WISM2/7510/8510/vWLC)
The HTML indexing of the 7.6 Configuration Guide on cisco.com is being updated, but here is the link to the PDF in the meantime:
http://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/7-6/configuration/guide/b_cg76.pdf (Chapter 5 Configuring 802.11ac Parameters)
Converged (3850/5760)
04-29-2014 12:32 PM
Hello!
What experience or best practice can you comment on from a channel overlap perspective with 80 MHz.
Can you go 36+ and 48- and overlap 2 channels ?
04-30-2014 09:23 AM
Hello George,
Cisco only allows you go choose from one of the 4 pre-built 80 MHz range 36-48, 52-64, 100-112, and 149-161. You will not be able to customize i.e. channel 40-52. Channels are bonded logically into one single pipe. Channel overlap in this case would be either single 80 MHz channel or none. Best practice use DCA.
Yilin
04-29-2014 01:58 PM
Hi Richard,
Thanks for sharing those useful links.
I am more interested in guidelines/best practices when migrate into 11ac from 11n network. Is that good idea to enabel 80MHz channel width across the board or is that something carefully plan where we want to go ? In typical university environment we have mix of high density & std density wifi deployments.
For 802.11n there is "Design & Deployment Guideline" doc available, wonder similar thing available for 802.11ac. Here is 11n doc I am referring to
Rasika
04-30-2014 08:08 AM
04-30-2014 07:37 AM
<moved to reply thread>
04-30-2014 07:37 AM
Hi Richard,
Based on your comment "DCA is 4-channel aware and will assign non-overlapping channels and channel-bonds across 11a, 11n, and 11ac APs."
Do you have any advice about overlapping channels, see my previous post.
04-30-2014 01:46 AM
I have seen that the "older" 3700 model comes with one 1 Gbps port while the "newer" 2700 model comes with two 1 Gbps ports.
Does that mean that we will need to plan in two cables per accesspoint in the future (802.11ac wave 2), or will you shift to 10 Gbps soon (which currently lacks a PoE standard)?
04-30-2014 07:39 AM
Great question - the 2nd gig port on the 2700 is a new feature to allow for a locally-attached auxiliary ethernet device (ceiling-mount LCD projector for example). In 7.6 code, that port will bridge to Gi0 so effectively it will be on the same VLAN as the AP. If the AP is in Flexconnect mode with Local Switching and VLAN Mapping, it is bridged to whatever the native VLAN is on the trunk.
My understanding is we may have more VLAN management options for it in future code, but I don't have anything definitive at this point.
04-30-2014 12:04 PM
Hi Richard,
I think you meant to say 8.0 code (instead of 7.6) as 2700 is not supported under current 7.6 release.
Rasika
04-30-2014 12:14 PM
Oops - spoiler alert 🙂
The first version of code to support the AP2700 and 700W series APs will be the next release of 7.6 which should be out in the next week or two. The beta of that 7.6MR2 image is currently posted on CSC if interested:
https://supportforums.cisco.com/document/12160571/76mr2-availability
04-30-2014 12:50 PM
Nice, did not know about that.
Thanks for the link for pre-7.6MR2. I think first time Cisco added new features like this onto a maintenance release 🙂
Rasika
05-02-2014 02:45 PM
Hello Richard and Yilin,
I'm not sure I understand what the differences are in the 11n and 11ac speed charts. Could you please explain what the MCS Index values are, and what spatial streams and guard intervals mean?
Thank you,
Evan
Hi Rasika,
We do not have an equivalent 11ac guide yet, but I reached-out to the Product Manager and there is one on the works right now and should be published soon.
In general, the framework and considerations of an 11ac deployment are very similar to 11n with respect to channel planning and coverage. The biggest difference being the need for 4 channels per AP (which can possibly create challenges if one avoids the use of DFS channels). But - in general, 11ac deployment within an existing 11n deployment is pretty clean from a controller/AP configuration standpoint. DCA is 4-channel aware and will assign non-overlapping channels and channel-bonds across 11a, 11n, and 11ac APs.
One thing we recommend is rebooting the WLC after deploying new 11ac-capable APs in an existing environment to allow DCA to run in Startup mode. For 11ac, we need 4 contiguous channels per 11ac-capable AP. Startup Mode allows for a green field to apply the most 'efficient' distribution of channels. This doesn't necessarily need to be done each time an 11ac-capable AP is deployed, but as a roll-out occurs or once all APs are in place it's a good idea.
Feel free to ask specific questions you may have - more than happy to try to answer them.
