05-15-2021 02:28 PM - edited 07-05-2021 01:18 PM
I work for an MSP and also do sales into some enterprise clients, I have a client with 4x 3602 APs and another 17x 3702 APs ready to be installed.
A colleague of his told him he needs a wireless controller now, he wants to know if that is a requirement, or just best practice (his colleague couldn't really elaborate why)
He has 3x 3750X (48port, POE) currently installed.
My current understanding is that he doesn't NEED a wireless controller at this point, but that it would just make managing things a lot easier, is that right or am I off-base here?
Thanks.
05-15-2021 02:47 PM - edited 05-16-2021 02:03 AM
You have pros and cons - how is your exiting AP managed?
WLC will give the advantage of many if you have more AP, centrally Managed and Other features are you mentioned.
you can find good document here :
https://heimdalsecurity.com/blog/what-is-wlc-in-networking/
=====️ Preenayamo Vasudevam ️=====
05-15-2021 05:11 PM - edited 05-15-2021 05:42 PM
@Orochimaru wrote:
he wants to know if
Whenever someone asks "if" a WLC is a requirement or not they are trying to justify the cost.
WLC is not just to simplify the management of the APs but the configuration of the APs, the operation of the wireless. It makes life a lot easier if the WLC is configured correctly.
When a number of autonomous APs boots up, for example, what channel are they all broadcasting? WLC will manage those channels and the radio power properly. Autonomous APs do not have that luxury.
Wireless operators with WLC, not just Cisco-branded ones, did not just jump into the WLC bandwagon for $hits-n-giggles.
With Cisco recommending people to go to the 9800, a lot of people are offloading the 2504 into the used market. The 2504, for example, can support up to 75 APs. The 5508 can support up to 500 APs.
05-15-2021 05:16 PM
05-17-2021 07:21 AM
Mobility Express is also an option. I don't have a lot of experience with it personally, but based on the scale of what you are looking at, it seems like it could be a decent and somewhat more affordable solution.
