AUP and authentication on 4400 controller?
johnny.schultz
I would like to know if authentication by username and password *and* the ability to force users to accept an "Acceptable Use Policy" is possible on a 4400 wireless controller. It appears as though they are mutually exclusive on the configuration page, ie., radio buttons to chose one or the other. This would be for users accessing the web through wireless access points. Any help would be appreciated. Thank you.
magress
If you are referring to web authentication - you could have a username and password and then code a "Acceptable Use Policy" that the user must confirm on the page before proceeding. You would configure the wlan for web authentication and then set the web authentication to external. The username/password would be setup in local net users on the WLC or you authentication server and then the coding for the page could be placed on your external web server.
