Authentication 9800-CL for web portal (admin access)
ryan14
I have setup radius auth for login to my WLC 9800-CL and it works for SSH but not the web gui login. Is there something special I need to do?
Current config:
aaa authentication login default group my-server local
Also, what is interesting is if I remove the default list and try to use a custom name, it does not work for ssh or http.
Config
aaa authentication login my_name group my-server local
balaji.bandi
admin user come with WLC always use local authentication as per i know) but you can create admin equivalent right users and authenticate again radius.
here is an example :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214490-configure-radius-and-tacacs-for-gui-and.html
BB
balaji.bandi
BB
Thanks that did it.
Here are the commands for future ref:
paolo-9800(config)#ip http authentication aaa login-authentication radAutheMethod
paolo-9800(config)#ip http authentication aaa exec-authorization radAuthzMethod
Glad that was helpfull and you able to resolve the issue.
BB
