Authentication Problem with Cisco AIR-CAP1602E-E-K9
A123450Ha
Community Member
Can someone please help me how to apply an authentication mentioned on mentioned modal of cisco ap.
I tried many time but could not do so.I want my SSID to broadcast which have done but is open authentication and everyone is able to connect the ap.
Thanks & Regards,
Joni..
Hi Joni,
That is Autonomous! No problem, try this to configure your SSID with a pre-shared key and encrypt with AES.
conf t
int d1
encryption vlan 102 mode ciphers aes-ccm
exit
dot11 ssid evo
authentication key-management wpa v 2
wpa-psk ascii 0 <CHOOSE KEY>
end
Ric
Please rate helpful / correct posts
10 Replies 10
Ric Beeching
Level 11
Level 11
Is this an autonmous SSID? Can you paste your config?
Ric
Thanks *Ric Beeching* to Reply
No, I think it is not in Autonomous. PFA the below attached configuration files with (show running-config & show version)
*Could it be the problem of it that it is not putting out authentication commands?
Joni..
Hi Joni,
conf t
int d1
exit
dot11 ssid evo
end
Ric
Hi Ric,
Thanks for your support. it have been done now(My issue cleared).
Joni..
Dear Ric,
My AP (AIR-CAP1602E-E-K9) is rebooting by itself after some time. Can you please help me to understand that what the problem is?
Will you please help me? I need your brotherly assistant on this issue.
Hope you may not be annoyed.
Joni..
I can try... are you running it off a power injector or a PoE switch? Do you see any logs on the switch if so?
Cheers,
Ric
HI,
Hope you are doing good.
Here,
1. My device is power up with an adopter and connected via Ethernet to my Cisco switch.
2. No, i didn't lookup any unknown logs on CLI.
Joni..
What power adapter are you using to provide power to the AP?
Can you paste the output of a 'show version' from your AP?
On your switch can you also do a 'show power inline'
Ric
Here,
1. I am using CP-PWR-CUBE-3 with Model: PSA18U-480(JMC).
but..!!!
Thanks a lot dear. My AP is placed in the critical wireless zone from where i could only be able to access via remote secession, i found here of socket problem whats why it is restarting by itself with random time space.
Thanks for you corporation..
<I would be happy to have you a friendly contact if you feel easy via fb or other? It will be a pleasure to me>
Joni..
Haha no problem I was going to suggest checking cables/plugs as it is often a physical issue. Glad you resolved it!
I'll have to pass on your generous offer, I'm only here to help others on the forum!
Ric
