authentication problem
ashish_gupta
Level 3
Level 3
I have four APs on a single floor. with chanels 1,4,7,11. The Clients are EAP authenticated .My problem is that some of the clients ( at some point of time one or the other user reports) go for re-authentication. The Server is placed globally where authentication takes place. As long as the wireless works it is fine but suddenly it starts aquiring address. This is particular with laptops having internal antenna. Also i enbled the registry settings for XP still no clue.
any help
thanks
ashish gupta
ashish_gupta
Level 3
Level 3
hi
There is also one machine which doesnt authenticates with the AP near it but with the far ones. I have seen the log files this m/c not even attempts to log into the near AP and reacts as if the AP doesnt exist.
I believe that association with AP is client property . Can i make it to authenticate with the near AP. The machine has intel wi-fi card (internal)
thanks
ashish gupta
