Authentication problems: 1232 A/G AP and Z-Com XI 325 client
airlink
We're having trouble getting our Z-Com radios connecting to 1232 APs. For the AP, we only have the "B" radio enabled, with everything set to defaults except the SSID and channel.
Z-Com cards are being used in Affirmative thin clients and when we switch cards to a Cisco 350 adapter, everything works fine.
Affirmative says that Z-com cards work perfectly with Cisco 1220B access points.
Any ideas?
b.hsu
Level 5
Level 5
What version of software are you running in the Ap's ?
