WLAN Roaming
paltel
Level 5
Level 5
I need to install WLAN at my building with 9 floors, i think the best solution is to run roaming between the APs, can anyone provide me with its documentation?
Or any other solution?
Thanks in advance
balajitvk
Level 8
Level 8
If you place the AP is different channel, it won't interfere with each other and your CPE will take the best signal it gets and connect to network thro. that AP seemlessly.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_data_sheet09186a00800f9ea7.html
depending if you will use a radius server for authentication, you can enable the AP to be WDS for fast roaming.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a0080208a6e.html
