Authentication process when roaming using PEAP ?
carl_townshend
Hi All
Can anyone tell me how the auth process works by default when roaming between access points using PEAP?
Does it reauth each time it goes to a new AP? or does the controller cache the authenticated session up until the session timeout?
What is session resumption used for? where is this set?
Also what is a good session timeout value in radius? we have ours set to one hour.
Many thanks
Carl
JPavonM
Hi Carl,
No it's not. Client doesn't need to the whole EAP process again. Only 4-way handshake is doen between client and AP
More information can be found here.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/116493-technote-technology-00.html#anc12
Regardinfg the timers for session timeout, I use to configure corporate sessions timeout for 24 hours, but for BYOD and guest devices only 30 minutes for them to reauthenticate.
-Jesus
*** Always Rate Helpful Responses ***
