auto vlan assignment
bluesea2010
Level 7
Level 7
I am planning to assign  vlan automatically based on active directory security group using ISE
ssid : abc
employees 10.0.5.0/24
managers 10.0.6.0/24
Do  i need to create a vlan group on wlc  for abc ?
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/99121-vlan-acs-ad-config.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
patoberli
No VLAN groups needed for this. You only need VLAN groups if you're out of addresses in VLANx and have created VLANy with a new DHCP pool for the additional clients. Then you can add those two VLANx and VLANy networks into one VLAN group and assign it to the SSID (or radius/ISE policy).
