I converted a Cisco Aironet 1142 Lightweight access point to Autonomous and at first it works properly but every some days the dot11Radio0 interface is down (similar case than the cisco support community case "Autonomous 1142 AP shuts down 2.4 radio interface"
The 802.11g radio shows as “Dot11Radio0 is reset, line protocol is down” while the 802.11a radio appears to be up and running,
I have to reload the device so that the Dot11Radio0 is up again,
Can you please give an idea how can I fix this?
Thank you,
David
