Bad Power Injector?
awairlines
Level 2
Level 2
I just received a new AIR-PWRINJ3 for my AP350 (someone lost the original one) and when I plug it in I get power, but nothing on the ethernet side. I've verified that the CAT5 cable, port and Access Point are in good working condition. Could it be a bad injector? I have a spare injector and when I plug it in place of the other one I get power on the AP. Thanks
thisisshanky
Level 11
Level 11
What does the power injector LED status indicate ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
The Power Status Indicator is green and there is nothing on the Device Status Indicator. This is the 2nd unit that I've tried with no luck. Vendor says now to call Cisco because the part # is "the correct one for replacement" for the AP350 and the 48 port blade (4006) doesn't have inline power.
Thanks in advance for your suggestions
