BBSM DHCP issue
sw1
Has anyone come across the problem whereby the BBSM has issued two IP addresses against the same MAC?? We run ver 5.3
hgauci
Community Member
Something similar has occured to me and it's giving me a big headache. In a nutshell the culprit is the DHCPRELEASE message generated by a client when it disassociates from an accesspoint or the client shuts down. When this happens the DHCP on the BBSM removes the lease causing the client to get a different IP next time it associates to the network. The problem is that this may happen in a shorter time than the porthop delay causing a stale session for that user. Is there a solution to this problem from Cisco?
