blue indicator light on 1131
lcaruso
Level 6
Level 6
The ringed indicator light on the 1131 normally glows green. What is indicated when it is glowing blue instead? Is this a power issue?
22 Replies 22
So it looks like the radio is up... so are you able to connect?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I was able to connect but I had to type in the SSID of the AP on an employees laptop.  I want the SSID to be broadcasted so that everyone can see it.  I just assumed after you enabled the radio and put the settings in it would automatically broadcast.
After I had a client associate to the AP.....the SSID seems to be broadcasting all of a sudden.  I'm worried what's going to happen when I change it to PoE.  Thank you for your help.
Alright same person different name.  I've been able to get the SSID broadcasting but it's also broadcasting "Other Network" even after turning some of the Guest SSID's on and off to see if anything made it go away.  Nothing has worked.
Post an updated show run-config.
You sure your not seeing the SSID from another ap that might have it broadcasting.
-Scott
Yeah I'm sure.  I deleted the SSID's and slowly started to narrow down what was causing the "Other Network" to pop up.  Whenever I add an SSID it will be shown as "Other Network".  There are other Cisco AP's in the company but they are all autonomous as well.  Here you go.  Currently I have it connected to the AC adapter not PoE.  Thank you.
CardpackAP>en
Password:
CardpackAP#show run
CardpackAP#show running-config
Building configuration...
Current configuration : 1668 bytes
version 12.3
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname CardpackAP
enable secret 5 $1$Iqff$NwLuIeARC7kTVaXtlHVIB0
ip subnet-zero
ip domain name westernind.com
ip name-server 192.168.34.32
no aaa new-model
dot11 ssid WTCardPacAP
   authentication open
dot11 arp-cache
power inline negotiation injector 000d.bddd.af03
power inline negotiation prestandard source
username Cisco privilege 15 password 7 072C285F4D06
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 325FBC3A76F96C750644B3A5B3B7 transmit-key
encryption mode wep mandatory
ssid WTCardPacAP
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0        54.0
packet retries 50
station-role root
rts threshold 500
rts retries 50
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.34.82 255.255.255.0
no ip route-cache
ip default-gateway 192.168.34.31
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
line vty 5 15
login
end
CardpackAP#
Scott Fella
To broadcast the SSID
authentication open
guest-mode
-Scott
I did this and the WTCardpacAP finally showed up.  However, the "Other Network" was still there.  I went into the GUI and saw there were two SSID's with the same name.  I deleted out the one that I just made through the CLI and it eliminated the "Other Network".  Although it seems fixed for now I wish I knew what I was doing wrong.  Thank you.
