Both EAP and WPA-PSK cannot be configured on same ssid
taimoor khan
Hey Guys,
I am trying to configure shared key with EAP and getting error messages, any help will be appreciated.
dot11 ssid TEST
   vlan 860
   authentication open eap eap_methods
   authentication network-eap leap_methods
   authentication key-management wpa version 2
AP-Test(config-ssid)#wpa-psk ascii 7 fldkfhl233
Error : Both EAP and WPA-PSK cannot be configured on same ssid.To configure WPA-PSK disable EAP
how do I resolve this issue ?
kcnajaf
Level 7
Level 7
Hi Taimoor,
There is no way to fix it :-)
As error message indicates you cannot have both PSK and EAP on the same SSID.
You could create two different SSID and have 1 configured with PSK and other configured with EAP.
Hope that helps.
Najaf
kcnajaf
Level 7
Level 7
Hi Taimoor,
Hope that helps.
Najaf
