BR 1310 Fastethernet Issue
Philip T Kurien
Hi Folks,
I am facing a strange issue with a Wireless Bridge Setup which i configured 3 days ago. Everything was working normal for a couple of days until yesterday when the setup stopped working.
On check what happened, this is what i was able to find:
I cannot ping one of the bridges from the directly connected switch. On checking the logs, there has been a continuous flapping of the ethernet link before it went down. But again if i console into the bridge and ping the bridge on the other side, it is successful.
So it looks as if the radios were working fine but the ethernet is not. Once i rebooted this bridge, it started to working again.
I am attaching the configuration for both the bridges and the logs that I was able to collect from the bridges.
Any sorts of inputs will be of great help.
Best Regards,
Philip
geraldccie
HELLO MAN,
i think ,am having the same problem...
look at it
When reloading the br 1310, the following error message appear
Error: timeout waiting for auto-negociation to complete
Error:fail to bring ethernet link up
Can someone Help PLZZZZZZ...
The ethernet LED is also down.
