05-26-2011 04:56 AM - edited 07-03-2021 08:15 PM
I've just installed a 2106 Controller at a remote site. The Controller is seen by the WCS at the main site so, connectivity is good and I'm able to login from the main site. I've configured the DHCP server which is at the Main site on the AP manager interface and the Manager interface and on the WLAN of the new controller but, APs are not getting addresses. Any ideas?
Thanks, Pat.
05-26-2011 06:38 AM
Where are your APs? Are they directly connected to your 2106, or are they connected to a switch like normal?
Assuming connected to a switch, the WLC config is irrelevant to an AP getting an IP address. Whatever vlan your APs are in, they'll do a broadcast dhcp request and you'll need an ip helper-address or something to get it to your dhcp server..............
So do you see any kind of dhcp request make it to your server?
If this is directly connected APs, then perhaps someone else on the forum can share thier experience with this?
-Wesley Terry
05-26-2011 07:34 AM
Terry,
thanks for the response. The APs are connected to the PoE ports on the Controller. On the AP interface I put port 1 for the Physical Information port, figuring this is where the Controller links to the network switch.
05-26-2011 11:36 AM
I think I figured it out. The APs are standalone and I ned to change them to LWAPP. Thanks.
05-27-2011 12:05 AM
Patrick,
For conversion please have a look on the video
https://supportforums.cisco.com/videos/2089
thanks.
05-27-2011 02:59 AM
Thank you Vinay. Good video.
Pat.
05-28-2011 10:03 AM
thanks Pat
