branch deployments using flex connect on 9800
AustinJ96TX
Community Member
I have to deploy APs to branches using flexconnect. Do i need to preconfigure the APs on my local controller then ship them out or can i just load in the MAC along with the tags i want on the AP ship it out and then itll grab everything it needs? everything else onsite is setup already like ports, DHCP, and whatever else it needs to reach back
Mark Elsen
           - You don't need to preconfigure the APs first ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Haydn Andrews
DHCP Option 43 at the site, if running DNAC you could also do PNP
I generally get the AP MAC address provided by the installer to map to the AP name and then push the config via the WLC when they come online.
If downtime is a concern or APs being installed into difficult to get to areas sometimes ill pre-stage before shipping to speed the process up.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Rich R
I personally don't recommend configuring each AP statically on the WLC - your config will get very big and unwieldy!
Use a well thought out naming scheme for your APs and then use regex filters to assign the tags when they join the WLC then all you need to do is set the AP name and the tags are automatic:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/newconfigmodel/b_catalyst-9800-configuration-model/m_creating-an-ap-filter.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#Assigningtags
And always use "show ap tag summ" to confirm the tag source is as expected.  If the AP didn't automatically re-join with correct tags after renaming you might sometimes have to do a capwap reset on the AP: ap name <apname> reset capwap
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
