Connectivity between Wireless controller and access point went down
swapnil.zambare
Visitor
If connectivity between WLC and AP goes down for sometime, will clients connected to AP's face network disruption? or there is any grace period that client's rest of use(browsing, access) will work.
5 Replies 5
If you use flex and central authc then endpoint will continue forward traffic until it re-authc and this point it need capwap to wlc for re-authc
If you use local AP then immediately endpoint will face traffic drop
MHM
Here re-auth are you referring for endpoints or Access point?
Once capwap is established, after how much time it will re-attempt to established?
Here re-auth are you referring for endpoints or Access point? Endpoints (wifi clients)
Once capwap is established, after how much time it will re-attempt to established? Can you elaborate
MHM
Mark Elsen
  - If the AP goes down then the  clients connected to AP's  will face network disruption?
    I don't include roaming here as a backup , because then that also must be possible ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
This doc was written for AireOS but little has changed on 9800.  It details which features can still work in standalone mode:
https://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-wlc-00.html
There's also some discussion in https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/FlexConnect_DG.html and the 9800 version of that https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/cat-9800-flexconnect-branch-deployment-guide-og.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
