Bridge-group 1 in a WLAN environment
mperduca
I'm configuring some AP 1130 AG.
For customer requirements I cannot use the VLAN 1 but in particular a VLAN 102 for the management and the VLAN 117 for the WiFi users. At this point I configured the switch port in trunk with the vlan 117 and 102 as native. In the AP I configured a fast ethernet interface0,vlan- id with the vlan-id ugual to the native vlan (102) I wrote also encapsulation dot1q 102 native. As bridge-group I tried to leave the bridge-group 1 but I lost the connection. If I put as bridge-group 102 all is ok. Why? I know that It is not necessary to specify the bridge group to which the FastEthernet interface 0.native_vlan_number belongs. It will be associated by default to the bridge group 1 used for the administration of the access point. I don't understand why? is there a link between bridge group 1 and vlan 1 (that I put down in the switch)?
gamccall
Level 4
Level 4
No, there is no link between a bridge-group/BVI number and a vlan number; they are completely independent.
Post your whole config and it'll be a lot easier for us to troubleshoot.
Thank you very much!
Here a piece of the conf:
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 117 mode ciphers tkip
ssid XYZ
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.102
encapsulation dot1Q 102 native
no ip route-cache
bridge-group 102
bridge-group 102 subscriber-loop-control
bridge-group 102 block-unknown-source
no bridge-group 102 source-learning
no bridge-group 102 unicast-flooding
bridge-group 102 spanning-disabled
interface Dot11Radio0.117
encapsulation dot1Q 117
no ip route-cache
bridge-group 117
bridge-group 117 subscriber-loop-control
bridge-group 117 block-unknown-source
no bridge-group 117 source-learning
no bridge-group 117 unicast-flooding
bridge-group 117 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 102 key 1 size 128bit 7 D27D726E54606C44B67B17586243 transmit-key
encryption vlan 102 mode wep mandatory
ssid ITC
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.102
ip address 172.44.12.20 255.255.255.0
no ip route-cache
bridge-group 102
interface FastEthernet0.117
ip address 172.44.17.20 255.255.255.0
no ip route-cache
bridge-group 117
interface BVI1
no ip address
no ip route-cache
ip default-gateway 172.44.17.1
radius-server host 172.21.3.2 auth-port 1812 acct-port 1813 key 7 adafsgvvf1234r
radius-server host 172.25.3.22 auth-port 1812 acct-port 1813 key 7 144fghnjgrgregh
bridge 1 route ip
Switch port configuration:
interface FastEthernet1/0/21
description To AP1130
switchport trunk native vlan 102
switchport mode trunk
switchport nonegotiate
