Bridge1300
ricardorojas123
Level 7
Level 7
HI, I have a doubt the bridge 1300 series, with connectors for external antennas,specifically the Cisco Aironet 1300 Series Outdoor Access Point/Bridge with RP-TNC Type Connectors
AIR-BR1310G-X-K9-R,
can be used both antennas, the internal antenna and the external one, at the same time? ...
Please respond to my doubt
thanks..
Rob Huffman
Hi Ricardo,
Your doubt is "well founded" The 1300 Series comes in two versions. One with Integrated Antennas and one with RP-TNC type connectors for external antennas. Neither model has both Internal and External Antennas;
The Cisco Aironet 1300 Series with integrated antenna can be quickly installed to provide a LAN bridge to a remote site or multiple sites. The 1300 Series with antenna connectors supports a variety of Cisco 2.4-GHz antennas, providing range and coverage versatility.
Antenna Interface
AIR-BR1310G-x-K9 or AIR-LAP1310G-x-K9:
Air interface (integrated directional antenna)
AIR-BR1310G-x-K9-R or AIR-LAP1310G-x-K9R:
Two RP-TNC type connectors for external antennas
From this good doc;
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a00802252e1.html
Hope this helps!
Rob
