Broadcasts rates on Radio and ethernet interface
john.wright
Level 3
Level 3
What is the difference between the broadcast rates that one sees on the radio interface verses the ehternet interface?
This is a sh inter that I did after a clear counters 7 min before.
S#sh inter | include l2|line|broadcast
BVI1 is up, line protocol is up
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
Dot11Radio0 is up, line protocol is up
     Received 67 broadcasts, 0 runts, 0 giants, 0 throttles
Dot11Radio0.1 is up, line protocol is up
Dot11Radio0.103 is up, line protocol is up
GigabitEthernet0 is up, line protocol is up
     Received 23105 broadcasts, 0 runts, 0 giants, 0 throttles
GigabitEthernet0.1 is up, line protocol is up
GigabitEthernet0.103 is up, line protocol is up
John Harrison
Hi John,
The received broadcasts shown in your CLI output is not a rate, but rather a total count of broadcast packets received on that interface. The difference in the count on your gig0 interface verses Rad0 simply means you have more traffic on gig0.
I hope this helps.
-John
John Harrison
Hi John,
I hope this helps.
-John
