Building to Building bridge
maurice.walsh
I need to link 2 buildings that are about 100m apart and have line of sight between them. The link needs to be reliable as I'm running a low bandwidth (64kb) realtime app over the Tcp/Ip bridge.
How reliable are the building to building bridges such as the 350's and what antennas should I be looking at for the link ? Is it easy to configure for an experienced network administrator ? and how easy is it to line up the antennas ?
Maurice Walsh
d.nogueira
At that distance even the rubber duck would work, however choose an antenna apropriate to the outdoor conditions you are going to have. As to reliabilty I have many of these links and haven't had any trouble from the majority of them. Also these link are pretty easy to install and configure. As to lining up the antennas if they are 100m apart its a piece of cake.
