C1852 Access Point Unable to Join Controller C5508
Tayyab831
Dear All,
Greetings,
I am  recently facing this problem my two 1852 APs are unable to join with controller. They were working fine for last six months but suddenly they are unable to join the  controller. Below are given complete boot up process output,
U-Boot 2012.07 (btldr release 31) (Mar 15 2017 - 15:00:35)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected SPANSION S34MS02G1 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:1], write_counter=8
PCI0 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832/1852 detected...
Power Type: 802.3af POE or Others detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
Specified BOOT: part2
Booting from part2
Read 1024 bytes from volume part2 to 45000000
Read 23462495 bytes from volume part2 to 45000000
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=30M@1280M console=ttyHSL1,9600n8 activepart=part2 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1600] CPU1: Booted secondary processor
[01/01/1970 00:00:00.2300]
[01/01/1970 00:00:00.2300] +++ hydra_ap_gpio_value =3
[01/01/1970 00:00:08.8074] [sched_delayed] sched: RT throttling activated
[01/01/1970 00:00:18.8843] ACPU PVS: 1
[01/01/1970 00:00:19.9039] buginf tty flushing thread started, ttyport=eec0c290
[01/01/1970 00:00:24.5325] msm_hsusb_host msm_hsusb_host: unable to find transceiver
[*01/01/1970 00:00:24.7724] buginf() enabled.
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
[*01/01/1970 00:00:24.7824] Made it into bootsh: Jun 4 2018 23:03:02
[*01/01/1970 00:00:24.7824] bootsh build T-5a1977b5600aa94dd31adcabae872ed6700b2ea1-g5a1977b5-vipendya
init started: BusyBox v1.23.2 (2018-06-04 22:46:06 PDT)
[*01/01/1970 00:00:27.8115] GCM-128 POST passed
[*01/01/1970 00:00:27.8115] GCM-256 POST passed
[*01/01/1970 00:00:28.0814] Active version: 8.3.143.0
[*01/01/1970 00:00:28.0814] Backup version: 8.2.151.0
[*01/01/1970 00:00:28.3013] AP1852I
Jan 1 00:00:28 FIPS[785]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*01/01/1970 00:00:28.4313] nss_driver - Turbo Support 1
[*01/01/1970 00:00:28.4313] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:28.5512]
[*01/01/1970 00:00:28.5512] phy_value=0: org="0x1000" phy_reg="0x1800"
[*01/01/1970 00:00:28.9311] Current value of FACTORY_RESET=0
[*01/01/1970 00:00:28.9511] Last reload time: Jul 26 06:19:32 2021
[*07/26/2021 06:19:32.0000] Setting system time Mon Jul 26 06:19:32 UTC 2021
[*07/26/2021 06:19:32.0699]
[*07/26/2021 06:19:32.0699] === 5G radio domain is 22, COPY 5G BDF files from non_ETSI_BDF folder ===
[*07/26/2021 06:19:32.1399] device wired0 entered promiscuous mode
[*07/26/2021 06:19:32.2399] device wired1 entered promiscuous mode
[*07/26/2021 06:19:32.6398] stile module dp init successfully
[*07/26/2021 06:19:32.6398] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Oct 4 2017 at 08:58:38
[*07/26/2021 06:19:33.2196] miibus get eec4b000!
[*07/26/2021 06:19:33.2496]
[*07/26/2021 06:19:33.2596] boot 2 build T-5a1977b5600aa94dd31adcabae872ed6700b2ea1-g5a1977b5-vipendya board corsica mac A0:F8:49:E4:20:10
[*07/26/2021 06:19:33.2596] Module: mbedtls .text=0xbf000000 data=0xbf007e18 bss=0xbf008070
[*07/26/2021 06:19:33.2596] Module: aptrace .text=0xbf00c000 data=0xbf0141dc bss=0xbf0145e0
[*07/26/2021 06:19:33.2596] Module: qca_nss_gmac .text=0xbf01b000 data=0xbf021b7c bss=0xbf02203c
[*07/26/2021 06:19:33.2596] Module: qca_nss_drv .text=0xbf02b000 data=0xbf042a40 bss=0xbf0437f0
[*07/26/2021 06:19:33.2596] Module: qca_nss_capwapmgr .text=0xbf05f000 data=0xbf062b78 bss=0xbf062cc8
[*07/26/2021 06:19:33.2596] Module: nssmgrctl .text=0xbf068000 data=0xbf069728 bss=0xbf069a4c
[*07/26/2021 06:19:33.2596] Module: proclikefs .text=0xbf06f000 data= bss=0xbf06fb40
[*07/26/2021 06:19:33.2596] Module: stile_lm_ft .text= data= bss=
[*07/26/2021 06:19:33.2596] Module: stile_lm_dp .text= data= bss=
[*07/26/2021 06:19:33.2596] Module: bonding .text=0xbf976000 data=0xbf98763c bss=0xbf987a68
[*07/26/2021 06:19:33.2596] Module: ipv6 .text=0xbf994000 data=0xbf9c4840 bss=0xbf9c60ec
[*07/26/2021 06:19:33.2596] Module: lowmemorykiller .text=0xbf9df000 data=0xbf9df2c0 bss=0xbf9df44c
[*07/26/2021 06:19:33.2596] Module: qca_nss_profile_drv .text=0xbf9e3000 data=0xbf9e4324 bss=0xbf9e4498
[*07/26/2021 06:19:33.2596] Module: ssdk_reg .text=0xbf9e9000 data= bss=0xbf9e9838
[*07/26/2021 06:19:33.6595] Last reload reason : 0: unknown
[*07/26/2021 06:19:35.2990]
[*07/26/2021 06:19:35.2990] __ol_ath_attach() Allocated scn c4080480
[*07/26/2021 06:19:35.3090] Chip id: 0x9, chip version: 0x1000000
[*07/26/2021 06:19:35.3090] Target Version is 1000000
[*07/26/2021 06:19:35.3090] Flash Download Address c0000
[*07/26/2021 06:19:35.3090] ol_transfer_bin_file: flash data file defined
[*07/26/2021 06:19:35.3090] Cal location [0]: 00000000
[*07/26/2021 06:19:35.3090] Wifi0 NAND FLASH Select OFFSET 0x1000
[*07/26/2021 06:19:35.3290] qc98xx_verify_checksum: flash checksum passed: 0x395b
[*07/26/2021 06:19:35.3290] ol_transfer_bin_file 4092: Download Flash data len 12064
[*07/26/2021 06:19:35.3490]
[*07/26/2021 06:19:35.3490] Board data initialized
[*07/26/2021 06:19:35.3989] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*07/26/2021 06:19:35.3989] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*07/26/2021 06:19:35.3989] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*07/26/2021 06:19:35.4789]
[*07/26/2021 06:19:35.4789] [Flash] : Ignore Module param
[*07/26/2021 06:19:35.4789] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*07/26/2021 06:19:35.4989] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*07/26/2021 06:19:36.5986] HTC Rx: insufficient length, got:4 expected =8
[*07/26/2021 06:19:36.5986] Startup Mode-0 set
[*07/26/2021 06:19:36.5986] HTC Service:0x0300 ep:1 TX flow control disabled
[*07/26/2021 06:19:36.5986] HTC Service:0x0100 ep:2 TX flow control disabled
[*07/26/2021 06:19:36.6086] Firmware_Build_Number:5
[*07/26/2021 06:19:36.6086] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffea
[*07/26/2021 06:19:36.6086] RES CFG Support wmi_service_bitmap 9778
[*07/26/2021 06:19:36.6086] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT
[*07/26/2021 06:19:36.6086] Mesh Supported
[*07/26/2021 06:19:36.6785] wmi_ready_event_rx: WMI UNIFIED READY event
[*07/26/2021 06:19:36.6885] ACS not enabled
[*07/26/2021 06:19:36.6885] ol_ath_thermal_mitigation_attach: --
[*07/26/2021 06:19:36.6985] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
[*07/26/2021 06:19:37.7182] FWLOG: [34136] WAL_DBGID_AST_DEL_WDS_ENTRY ( 0xdeadc0de, 0xea, 0x32 )
[*07/26/2021 06:19:37.7182] FWLOG: [34208] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/26/2021 06:19:37.7182] FWLOG: [34208] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/26/2021 06:19:37.7182] FWLOG: [34208] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/26/2021 06:19:37.7182] FWLOG: [34208] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/26/2021 06:19:39.7876] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*07/26/2021 06:19:39.8675] pid 1626's current affinity mask: 3
[*07/26/2021 06:19:39.8675] pid 1626's new affinity mask: 1
[*07/26/2021 06:19:42.4568] wired0: 1000 Mbps Full Duplex
[*07/26/2021 06:19:42.5867]
[*07/26/2021 06:19:42.5867] Click sched monitor: schedulers = 1
[*07/26/2021 06:19:44.2862]
[*07/26/2021 06:19:44.2862] phy_value=0: org="0x1800" phy_reg="0x1000"
[*07/26/2021 06:19:55.9825] Loading sha2...
[*07/26/2021 06:19:55.9825] Dumpping sha1...
[*07/26/2021 06:19:57.6320] Loading MIC cert and key
[*07/26/2021 06:19:57.6420] Dumpping sha2...
[*07/26/2021 06:19:59.3615] Loading MIC cert and key
[*07/26/2021 06:19:59.7214] Generating key, this may take a while...
[*07/26/2021 06:20:01.6108] Public key portion is:
[*07/26/2021 06:20:01.6108] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCypDtMQaNAM2PMQ9pQ1xt64yzjihYhMRmxBOBytl3qt3Z3ebtabXo8cPQMiVDD5MrN6Blgda1OZgIeQxklmhTNK4Xc/026/KwPObuJ54jitRwF+6NROxQyxIyQPW3ft/7eAmOdeHWtW3Sl6HxIOQ0YD1+oIu2/IOOoMUTRxtnfkdTvfm17onKy7uZZZa6x1qYeCHIuLGogAjKDwmPlEgv9yvxBlBzU93TEL9mPBVK52bG07/Xyw/yjqH1hbeUOE/iRqpSvTCdYXb25EQN1nEIMrK/0MdKEtyhbg9h/QCFbQhxrVoVgG/5ET4ZgfB7zA8KL7dbsaH23EV3PREuDwmO1 root@mA0F849E42010
[*07/26/2021 06:20:01.6108] Fingerprint: md5 5c:e8:a6:53:29:71:5e:6c:b0:96:ad:47:47:36:3d:ad
[*07/26/2021 06:20:01.6708] pid 2707's current affinity mask: 3
[*07/26/2021 06:20:01.6708] pid 2707's new affinity mask: 1
[*07/26/2021 06:20:02.1206] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/1/g' -e 's/__DOMAIN_5G__/22/g' -e 's/__PRODUCT_ID__/AIR-AP1852E-C-K9/g' -e 's/__AP_TYPE__/47/g' -e 's/__WIRELESS_MAC__/A0:F8:49:E4:D9:60/g' -e 's/__WIRED_MAC__/A0:F8:49:E4:20:10/g' -e 's/__WIRED1_MAC__/A0:F8:49:E4:20:10/g' | DMALLOC_OPTIONS=debug=0x03,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*07/26/2021 06:20:02.5905] Password for 'Cisco' changed
[*07/26/2021 06:20:03.6302] DOT11_DRV[0]: Init Radio0
[*07/26/2021 06:20:03.6502] DOT11_DRV[0]: Stop Radio0
[*07/26/2021 06:20:03.6502] DOT11_DRV[0]: set_channel Channel set to 6
[*07/26/2021 06:20:03.6601] DOT11_DRV[1]: Init Radio1
[*07/26/2021 06:20:03.6601] DOT11_DRV[1]: wifi1: Failed to get radio priv parameter (op 4234)
[*07/26/2021 06:20:03.6801] wifi1 no private ioctls.
[*07/26/2021 06:20:03.6901] wifi1 no private ioctls.
[*07/26/2021 06:20:03.7001] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4283 arg 1)
[*07/26/2021 06:20:03.7001] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No such device)
[*07/26/2021 06:20:03.7001] DOT11_DRV[1]: acfg_set_radio_param param 0x200d value 1 failed
[*07/26/2021 06:20:03.7101] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No such device)
[*07/26/2021 06:20:03.7101] DOT11_DRV[1]: acfg_set_radio_param param 0x2017 value 1 failed
[*07/26/2021 06:20:03.7101] DOT11_DRV[1]: wifi1 acfg cmd 19 failed for wifi1 errno 19(No such device)
[*07/26/2021 06:20:03.7101] DOT11_DRV[1]: Radio 1 NF_Calibration request failed !
[*07/26/2021 06:20:03.7101] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4176 arg 1)
[*07/26/2021 06:20:03.7201] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4235 arg 1)
[*07/26/2021 06:20:03.7201] DOT11_DRV[1]: wifi1 acfg cmd 16 failed for wifi1 errno 19(No such device)
[*07/26/2021 06:20:03.7201] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*07/26/2021 06:20:03.7201] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:6F
[*07/26/2021 06:20:03.7301] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*07/26/2021 06:20:03.7301] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:6E
[*07/26/2021 06:20:03.7301] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*07/26/2021 06:20:03.7301] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:6D
[*07/26/2021 06:20:03.7401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*07/26/2021 06:20:03.7401] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:6C
[*07/26/2021 06:20:03.7401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*07/26/2021 06:20:03.7401] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:6B
[*07/26/2021 06:20:03.7401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*07/26/2021 06:20:03.7401] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:6A
[*07/26/2021 06:20:03.7501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*07/26/2021 06:20:03.7501] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:69
[*07/26/2021 06:20:03.7501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*07/26/2021 06:20:03.7501] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:68
[*07/26/2021 06:20:03.7501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*07/26/2021 06:20:03.7501] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:67
[*07/26/2021 06:20:03.7601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
[*07/26/2021 06:20:03.7601] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:66
[*07/26/2021 06:20:03.7601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v10 error No such device
[*07/26/2021 06:20:03.7601] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:65
[*07/26/2021 06:20:03.7701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v11 error No such device
[*07/26/2021 06:20:03.7701] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:64
[*07/26/2021 06:20:03.7701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v12 error No such device
[*07/26/2021 06:20:03.7701] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:63
[*07/26/2021 06:20:03.7701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v13 error No such device
[*07/26/2021 06:20:03.7701] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:62
[*07/26/2021 06:20:03.7801] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v14 error No such device
[*07/26/2021 06:20:03.7801] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:61
[*07/26/2021 06:20:03.7801] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v15 error No such device
[*07/26/2021 06:20:03.7801] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: A0:F8:49:E4:D9:60
[*07/26/2021 06:20:03.7801] DOT11_DRV[1]: Stop Radio1
[*07/26/2021 06:20:03.7901] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_stop_radio ioctl SIOCGIFFLAGS failed for wifi1 error -1
[*07/26/2021 06:20:03.7901] DOT11_DRV[1]: Failure to Stop radio during Base Driver Initialization
[*07/26/2021 06:20:03.7901] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*07/26/2021 06:20:03.7901] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*07/26/2021 06:20:03.8001] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*07/26/2021 06:20:03.8001] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*07/26/2021 06:20:03.8001] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*07/26/2021 06:20:03.8101] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*07/26/2021 06:20:03.8101] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*07/26/2021 06:20:03.8101] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*07/26/2021 06:20:03.8201] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*07/26/2021 06:20:03.8201] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*07/26/2021 06:20:03.8201] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*07/26/2021 06:20:03.8301] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*07/26/2021 06:20:03.8301] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*07/26/2021 06:20:03.8301] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*07/26/2021 06:20:03.8401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v14 error No such device
[*07/26/2021 06:20:03.8401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v15 error No such device
[*07/26/2021 06:20:03.8401] DOT11_DRV[1]: mon1 ioctl op=0x8bf2 len=4 failed: 19 (No such device)
[*07/26/2021 06:20:03.8401] DOT11_DRV[1]: set mode_str 11A to mon1 failed
[*07/26/2021 06:20:03.8501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*07/26/2021 06:20:03.8501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*07/26/2021 06:20:03.8501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*07/26/2021 06:20:03.8601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*07/26/2021 06:20:03.8601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*07/26/2021 06:20:03.8601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*07/26/2021 06:20:03.8701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*07/26/2021 06:20:03.8701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*07/26/2021 06:20:03.8701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*07/26/2021 06:20:03.8801] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*07/26/2021 06:20:03.8801] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*07/26/2021 06:20:03.8901] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*07/26/2021 06:20:03.8901] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*07/26/2021 06:20:03.8901] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*07/26/2021 06:20:03.9001] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v14 error No such device
[*07/26/2021 06:20:03.9001] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v15 error No such device
[*07/26/2021 06:20:03.9001] DOT11_DRV[1]: mon1 acfg cmd 30 failed for mon1 errno 19(No such device)
[*07/26/2021 06:20:03.9001] DOT11_DRV[1]: set_channel Channel set to 149
[*07/26/2021 06:20:03.9101] DOT11_DRV[1]: wifi1 acfg cmd 17 failed for wifi1 errno 19(No such device)
[*07/26/2021 06:20:03.9101] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4242 arg 0)
[*07/26/2021 06:20:03.9101] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4241 arg 0)
[*07/26/2021 06:20:03.9201] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*07/26/2021 06:20:03.9201] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*07/26/2021 06:20:03.9201] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*07/26/2021 06:20:03.9301] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*07/26/2021 06:20:03.9301] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*07/26/2021 06:20:03.9401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*07/26/2021 06:20:03.9401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*07/26/2021 06:20:03.9401] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*07/26/2021 06:20:03.9501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*07/26/2021 06:20:03.9501] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
[*07/26/2021 06:20:03.9601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v10 error No such device
[*07/26/2021 06:20:03.9601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v11 error No such device
[*07/26/2021 06:20:03.9601] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v12 error No such device
[*07/26/2021 06:20:03.9701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v13 error No such device
[*07/26/2021 06:20:03.9701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v14 error No such device
[*07/26/2021 06:20:03.9701] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v15 error No such device
[*07/26/2021 06:20:03.9800] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver get_vap_if_index ioctl SIOCGIFINDEX failed for apr1v0 error No such device
[*07/26/2021 06:20:03.9800] wcpd: /san/BUILD/workspace/83MR4_Repost_Cheetah_CCO/label/corsica/base/../elts-meraki/elements/wcp/wcp_db.cc: 1366: void WcpDb::populate_if_index_table(): Assertion `if_index >= 0 && if_index < 64' failed.
[*07/26/2021 06:20:10.3781] ethernet_port wired0, ip 10.15.12.157, netmask 255.255.255.0, gw 10.15.12.1, mtu 1500, bcast 10.15.12.255, dns1 10.11.12.5, dns2 10.11.12.6, domain fccollege.edu.pk
Username:
[*07/26/2021 06:20:37.5296] !!!!! {watchdogd} Process wcpd gone for 60s
[*07/26/2021 06:20:37.5296] !!!!! {watchdogd} Process capwapd no heartbeat for 60s
[*07/26/2021 06:21:02.6717] waiting for WCP to initialize
[*07/26/2021 06:21:02.6717] Socket Invalid Element wcp/wcp_db Handler has_rlan Data 0 Length 10
[*07/26/2021 06:21:02.7117] AP IPv4 Address updated from 0.0.0.0 to 10.15.12.157
[*07/26/2021 06:21:02.7317] dtls_init: Use MIC device cert
[*07/26/2021 06:21:02.7317] dtls_init: Use MIC device cert private key
[*07/26/2021 06:21:02.7317] CAPWAP State: Init
[*07/26/2021 06:21:02.7317] Config not found, PNP is required, Starting PNP
[*07/26/2021 06:21:25.5346] PNP Discovery Timer Expired, Starting CAPWAP Discovery
[*07/26/2021 06:21:25.5346] CAPWAP State: Discovery
[*07/26/2021 06:21:25.5446] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/26/2021 06:21:25.5446] CAPWAP State: Discovery
[*07/26/2021 06:21:35.0516]
[*07/26/2021 06:21:35.0516] CAPWAP State: Discovery
[*07/26/2021 06:21:35.0616] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/26/2021 06:21:42.5792]
[*07/26/2021 06:21:42.5792] !!!!! {watchdogd} Process wcpd gone for 120s
[*07/26/2021 06:21:44.5486]
[*07/26/2021 06:21:44.5486] CAPWAP State: Discovery
[*07/26/2021 06:21:44.5586] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/26/2021 06:21:54.0557]
[*07/26/2021 06:21:54.0557] CAPWAP State: Discovery
[*07/26/2021 06:21:54.0656] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/26/2021 06:22:03.5627]
[*07/26/2021 06:22:03.5627] CAPWAP State: Discovery
[*07/26/2021 06:22:03.5727] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
Could you please confirm is it related to software bug problem or device hardware issue?
25 Replies 25
As to your original question I'd say the hardware has failed and you need to replace the APs.
Make sure the replacements are bought with correct reg domain.
Thank you very much for your reply. Could you please elaborate which things in logs are mentioning that the device has been faulty?
Tayyab
I believe that's telling you it can't find the radio.
As in outuput of show version of AP one radio is showing,
2 Gigabit Ethernet interfaces
1 802.11 Radios
if one radio is faulty but 2nd one is available, what do you think does it should work? or we assume the complete hardware faulty of device?
That's a question you'd have to ask Cisco TAC.
But I don't think there's any point in asking - you've already proven empirically that it does not work.
From what I've seen on similar 1832 failures the AP sends invalid data (missing message elements for WTP Board Data and WTP Descriptor) in the CAPWAP discovery request and that's why it's never able to join because the WLC ignores the invalid discovery requests.  While that may itself be a bug in AP COS it's really just a symptom of the failed hardware so the solution is replacing the failed hardware.
Thanks alot for your response. I really appreciate it.  I find one thing in the output of the AP show ip interface brief output is given below,
APA0F8.49E4.2010#sh ip int brief
Interface  IP-Address      Method   Status                 Protocol   Speed
wired0     10.15.12.157    DHCP     up                     up         1000
wired1     unassigned      unset    down                   up         n/a
wifi0      unassigned      unset    administatively down   down       n/a
srcr6      unassigned      unset    up                     up         n/a
  In output faulty radio (wifi1 is not showing) but wifi0 is administatively down. I tried to up but not done. In earlier APs command debug capwap console cil work to enable configure terminal of the AP but in this platform this is not working. Can you please tell me how can i enable/up wifi0 interface? If one radio interface will up and may be the AP can join the controller.
- CAPWAP AP must be configured by WLC you cannot configure it manually by CLI
- I already explained why the AP can't join the WLC but feel free to get your own packet captures to see whether it's the same problem I expect it is.
- Rather than wasting time trying to make a faulty AP work, replace it.
Thank you very much for your efforts and dedication. Actually, our two APs have been faulty for the same reasons recently one by one and about 10 APs are working in the network. That is why I wanted to make sure the  AP hardware problem and you explained it clearly.
Once again Bundle of Thanks.
Unless Cisco policy have changed, one cannot just RMA one Regulatory Domain and get another one back.
I assumed these would not be RMA'd @Leo Laohoo which is why I said "bought" not RMA
Thanks,Noted. We will buy new APs. We do not have RMA against these APs now. Could you please elaborate which things in logs are mentioning that the device has been faulty?
