C9120AXP and AIR-ANT2513P4M-NS Compatibility
Paul47
Folks, I'm having a hard time determining if the C9120AXP access point and the AIR-ANT2513P4M-NS are compatible.
This is for an internal warehouse implementation. I see pages that specifically state the C9124AXP is compatible, but that's an external AP and this is for internal use.
Can someone direct me? I always get stuck trying to navigate wifi/antenna compatibility.
Rich R
@Saikat Nandy 's answer actually comes directly from the 9120 datasheet:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9120ax-series-access-points/datasheet-c78-742115.html#Productspecifications
Leo Laohoo
As far as I am aware, C9120AXP is compatible with the AIR-ANT2513P4M.
Saikat Nandy
Cisco Catalyst 9120AXP Access Points are certified for use with antenna gains up to 13 dBi (2.4 GHz and 5 GHz) with the AIR-ANT2513P4M-N= antenna
Rich R
 There it is, thank you.
