C9124 Mesh VLAN question
Alex49
Hi to all,
I need the secondary POE OUT Port on the C9124 in vlan 99
RAP switch config > trunk with native vlan 201 , which is my mgmt for my access points
RAP config > see picture 1
MAP config > see picture 2
I can ping RAP and MAP.
VLAN Transparent and Ethernet Bridging is enabled
How can I assign the POE OUT Port on the MAP to vlan 99 to connect a camera
Thanks in advance
marce1000
          - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwf93499
 M.
Rich R
I guess it depends whether you're trying to bridge vlan 99 from RAP to MAP which should work or MAP to WLC which will not work as per the bug Marce referenced.
Any reason why you don't have VLAN Trunking Native ticked while configuring a native VLAN on the MAP port?
Have you configured Ethernet Bridging on the mesh profile as per https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215100-join-mesh-aps-to-catalyst-9800-wireless.html for the bridging to work?
