C9124AXE
sammirajkumar
Community Member
How increase transmit power in C9124AXE AP Device
@sammirajkumar
 Is it working as standalone or joined in Wireless lan controler? Which kind of access to you have to it? HTTP, CLI or both?
5 Replies 5
@sammirajkumar
Both
did you setup the EWC on it already?
Leo Laohoo
In other development, please keep the number of wireless client connected to a single 910x, 911x or 912x down to <15.  If the wireless client >25, the 910x, 911x or 912x will quickly run out of memory and the affected AP will crash.
It would be a good idea to consider rebooting the APs daily.
Please refer to CSCvy08682.
Oh, one important thing:  Cisco is NOT FIXING this bug.
Rich R
Transmit power will be the result of a combination of:
- what antenna you use
- Regulatory domain of AP and country setting
- Band and channel in use
Detailed Channels and Maximum Power Settings for Cisco Catalyst Wireless 9124AXE Outdoor Access Points, Release 17.15.1
- Your RRM settings on the RF profile for that AP
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
