C9800 17.9.x - not compatible with ISE 3.1 ?
it-lisens
We are running ISE 3.1 and I have plans to upgrade the C9800 to 17.9.x (which is the recommended one). But I see in the release notes that ISE 3.1 is not listed in the compatibility matrix.
Is it true that ISE 3.1 is not supported?!
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/release-notes/rn-17-9-9800.html#id_104423
As per the Wireless Solution Software Compatibility Matrix Table 1. it is compatible.
Ref: https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#cat-9800_ctrls
CJ
CJ
Dustin Anderson
I'm guessing the doc is just not updated when it lists back to 2.4. I doubt you would have issues, but you should have some test wireless to verify with.
If it only listed 3.2 I would be more wary, but I haven't seen issues with newer ISE code dropping compatibility.
