C9800-40 / 80 RP port statistics and SFP
Johannes Luther
Level 4
Level 4
Hi wireless professionals,
is there any way to see counters of the RP (fiber) interface? For the fiber port it would be good to see which SFP is installed.
So in fact something like a "show interface" / "show interface transceiver" for the RP port.
8 Replies 8
Leo Laohoo
show interface status
show interface <PORT>
Hey Leo,
this does not work for the RP port. Right?
RP?  You mean Redundancy Port?
I do not think there is a show command to see the counters for the RP and SP.
marce1000
          - What about :  show redundancy counters
 M.
Tony Rosolek
As packet counter the best I can find is "show redundancy counters" as already mentioned by marce1000.
WLC#sh redundancy counters
Redundancy Facility OMs
comm link up = 24
comm link down = 24
invalid client tx = 0
null tx by client = 0
tx failures = 0
tx msg length invalid = 0
client not rxing msgs = 0
rx peer msg routing errors = 0
null peer msg rx = 0
errored peer msg rx = 0
buffers tx = 10986
tx buffers unavailable = 0
buffers rx = 14272
buffer release errors = 0
duplicate client registers = 0
failed to register client = 0
Invalid client syncs = 0
And you might be able to find SFP type and information with "show inventory" command. I'm unable to test it, because I use cooper RP port.
||| Please rate helpful posts. Thanks! |||
crange
Hello everyone, in WLC 9800-40 what is the way to check which RP is being in use? there are two option Copper and Fiber
 - Checkout these commands :
         show platform hardware slot R0 ha_port sfp idprom
         show platform hardware slot R0 ha_port interface stats
 M.
Thanks, I really appreciate it
