C9800 Web Auth
hs08
I try create SSID with Web auth for my guest. When i select 'none' in Layer2 security and tick Web Policy in Layer3 why the SSID is not showing? If i untick the Web Policy in Layer3 then the SSID is showing with open authentication.
From my experience @hs08 yes any inconsistency in the config can prevent the WLAN from being pushed to the AP.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
11 Replies 11
Mark Elsen
  - If the SSID is  not showing enter the CLI command wireless config validate
    In those circumstances also validate the controller configuration using the CLI command
     show tech wireless and feed the output from that into Wireless Config Analyzer
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I think I have issue with web auth because if I not tick the 'Web Policy' then the SSID is showing.
  - @hs08       Yet my verification advices remain mandatory tasks to execute,
  M.
Saikat Nandy
'show tech wireless' please as well as the ssid name.
the SSID name is SEG-GUEST1
 - @hs08                 I have had wlc.txt analyzed with Wireless Config Analyzer
                               One of the observed results :
Webauth: WLAN with webauth configured, but no aaa authorization network command detected. This may be incomplete configuration
Action: For webauth, you should set a network authorization method. For more information: https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/16-11/config-guide/b_wl_16_11_cg/cisco-guest-foreign.html
        Use WirelessAnalyzer your self for   viewing all results,   (Wireless Config Analyzer)
                         When making changes use WirelessAnalyzer again!!
  M
hi @Mark Elsen
I know but want to know if the web auth is not yet complete configured this will make the SSID not visible?
  - @hs08   I would suppose yes ; configurations must always be complete and correct,
  M.
Based on your config, I am not seeing any 'obvious' reason why the SSID won't be visible after selecting None in Layer 2 and enabling Layer 3 in Web Policy. Everything looks to be in place from config perspective. If you ssh into the AP and do 'show dot11 wlan', do you see the SSID as Up?
Rich R
There is a LOT more to configuring web auth than just one tick box!
Have you followed all the required steps in the relevant guide?
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213920-central-web-authentication-cwa-on-cata.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-l-wireless-controller/220405-configure-local-web-authentication-with.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217457-configure-and-troubleshoot-external-web.html
