Cabling Issue
rx33328
Community Member
We were using UC4800 universal clients connected to P.C.'s and printer via straight thru ethernet cables to attach to the network(AP4800E). Because Cisco no longer manufacures the UC4800E we purchased the Air-WGB350. It appears that we now have to use a crossover cable when attaching these to P.C.'s and printers. Is there a switch, software or hardware, that allows me to use a straight thru ethernet cable?
shaun.oliver
Level 4
Level 4
Either replace the (current) straight-through cables with crossover cables, or (if it's a cable run) you could probably get away with an inline coupler & short crossover on the end of the existing cable.
