11-28-2022
12:21 AM
- last edited on
11-28-2022
12:23 AM
by
Yanli Sun
There are two SSID under 9800, SSID1 and SSID2
Can I make a PC to SSID1 only, not to SSID2?
11-28-2022 01:16 AM
- Connecting to the SSID can not be attempted, it's the same as attaching a network cable to any sort of PC , it are the authentication schemes behind the SSID which determine if that network can effectively be used.
M.
11-28-2022 01:35 AM
Yes, SCOM can specify what SSID is preferred by the machine.
11-28-2022 02:38 PM
You would have to do some type of MAC authentication...
12-06-2022 11:17 PM
username XXXX mac wlan-profile-name SSID1
Qualified when wlan-profile-name is specified. However, it must be a SSID for MAB/Dot1x, and a SSID for PSK/OPEN cannot be throttled.
