08-16-2018 09:05 AM - edited 07-05-2021 08:59 AM
We have some of the AIR-AP3802I-B-K9C APs that come with a Mobility Express image on them. If I connect these to a network with a WLC 5508, will the APs discover the controller and download a new image from the controller and work, or do I have to manually remove and add a new image to them?
Thanks!
08-16-2018 09:08 AM
Hi, you need to convert the mobility express AP to CAPWAP. From the CLI:
ap-type capwap
08-16-2018 11:00 AM
Thanks for the link to the article - one follow up question.
The process from the link says to:
1. Connect to the Console Port, Telnet or SSH to the AP.
2. Login to the Mobility Express controller console.
3. In the Mobility Express controller console, use the command apciscoshell to connect to the AP console.
4. Login to the AP console using the username Cisco and password Cisco. Both are case-sensitive.
5. Enter enable.
6. Enter the command ap-type capwap, and confirm .
We never set these APs up, and are not familiar with Mobility Express. So I'm not sure what is entailed with steps 2 and 3. Do you know how you log into the "Mobility Express controller console"? Is that on the AP itself? Username/Password? Does anything need to be setup elsewhere?
Thanks again!
08-16-2018 11:51 AM
Hi, you can use a standard Cisco console cable and connect to the blue port on the back of the AP.
If you don't have one you can ssh into the IP address of the mobility controller. This will ask you for a username and password.
Once entered follow the commands in the guide, nothing else needed then to allow them to search for a WLC using capwap.
08-16-2018 11:53 AM
Is the mobility controller embedded in the AP or something separate?
08-16-2018 01:18 PM
If you know the management IP address for the APs then that is the controller one that you are logging into.
