Can C9115AXE AP able to Join on C2504 Hardware controller ?
supportahm
Dear All,
I have C9115AXE AP which is running on firmware 17.13.0 and i want know that it is supported join on C2504 Hardware controller ( controller running on 8.3.150 version ) ?
I also referred escalation matrix of wireless solution but not able to find match answer .
Waiting for your valuable response
Thanks & Regards
Dhaval
2 Accepted Solutions
 - Your wireless controller model (2504) can not run that version designated for higher models ; that means that if you need to support the C9115AXE  AP's in your network ; then you will need to change & upgrade the controller to a newer model ; preferably a 9800 based controller model ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
To summarise all the other answers:
Can C9115AXE AP able to Join on C2504 Hardware controller ? NO
If you want to use the 9115 AP you will have to upgrade the WLC to a currently supported model like 9800 series.
https://www.cisco.com/site/uk/en/products/networking/wireless/wireless-lan-controllers/catalyst-9800-series/index.html
6 Replies 6
Leo Laohoo
911x requires 8.9.X.X or IOS-XE version 16.11.X as a minimum.
Dear Leo,
I am not understand properly can you elaborate for the same (911x requires 8.9.X.X or IOS-XE version 16.11.X as a minimum.)
   >I am not understand properly can you elaborate for the same (911x requires 8.9.X.X or IOS-XE version 16.11.X as a minimum.)
              Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
 Table 7 :  (in green is the minimum aireos version needed ; older versions wont work
9115
C9115AXI-x
8.9.100.0
8.10.x
Cisco IOS XE Gibraltar 16.11.1b
C9115AXE-x
8.10.x
       Beauty and terror
      Just keep going
       No feeling is final
Dear Team,
Thanks For your response .
As per check on cisco software platform I am not able to see firmware version 8.9.100 ,showing upto 8.5.182.0
Please find attached Snap-shot for your reference.
Thanks & Regards
Dhaval
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Rich R
