Migrating APs from EWC AP 9115 to WLC 9800?
Rizky Chandra
Hello, I have 5508 WLC for around 5 years and managing Cisco AP's modeled 1832, 1831, 1815, 2600, 2700, and 2800 on my office
6 months ago we bought 10 units Cisco AP 9115ax and use EWC as the 9115ax controller, but we've recently bought WLC 9800 planning to managed all model Cisco AP unit above. how do I migrate the AP's from EWC to the newly bought 9800, and also how can I migrate all the AP's from old WLC to the new WLC?
the list of Access Point from old WLC is shown below
Leo Laohoo
2600 will not be supported on the 9800.
do I need to release the other AP's that compatible with 9800 WLC? how to do that?
marce1000
                    >...and also how can I migrate all the AP's from old WLC to the new WLC?
 - Check https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html  , pay attention to needed software version(s) for older APs and future support.
                                Use DHCP option 43 , to led APs discover the correct controller.
  - Further check reply from Arshad Safrulla in  https://community.cisco.com/t5/wireless/migrating-9120-ewc-to-9800-wlc/td-p/4687229
  - Review the intended configuration of the WLC 9800 before production use with the CLI command show tech wireless and feed the output into Wireless Config Analyzer
 M.
Rich R
Also refer to https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html#Conversion and https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html#MigratinganEWCnetworktoacontrollerbasednetwork
