Can changing the PSK on a wireless controller be scripted?
PJV
Community Member
Any suggestions for how to automate a monthly change to the PSK for the guest wireless ssid.  Attempts to connect to the wireless controllers in Powershell with poshssh and plink run into issues trying to authenticate. The first prompt at login being "login as" rather then user as is the case with most ssh connections.
9 Replies 9
jcohoe
Hello, have you tried using Ansible with the aireos_config and aireos_command modules?
PJV
Community Member
I have not tried Ansible. Can you point me to an example using Ansible?
jcohoe
Hi, we are planning to release a blog post in March, to coincide with the Ansible release. Their release has a fix for both "legacy" and the new SSH mechanisms within AireOS. As you may be aware, in AireOS 8.6+ the CLI wrapper around the authentication is disabled by default, providing a more native SSH experience. Prior to 8.6 there is a wrapper around the authentication, which is where your powershell etc scripts are likely failing.
To work around this, you could try upgrading to 8.6+ code (recommend 8.8). However I understand this is much easier said that done 🙂
There is a video showing this in action: https://www.youtube.com/watch?v=KIJBE9DVMDA
Here is the config for Ansible
aireos_hosts.txt
[all:vars]
ansible_connection=local
ansible_user=your_wlc_username
ansible_password=your_wlc_password
ansible_port=22
[aireoswlc]
wlc1 ansible_host=10.10.10.2
aireos_show.yaml
- hosts: aireoswlc
  gather_facts: no
  tasks:
   - aireos_command:
      commands:
       - show boot
     register: show
   - debug: var=show.stdout_lines
Execute the playbook with:
ansible-playbook -i ./aireos_hosts.txt ./aireos_show.yaml
Documentation on the 2 modules are available at:
https://docs.ansible.com/ansible/2.4/aireos_command_module.html
https://docs.ansible.com/ansible/2.4/aireos_config_module.html
Jeremy
PJV
Community Member
Thank you for all the responses. Our device is a Cisco 5508 WLC . The latest version I can find is 8.5 . Can anyone confirm that this supports the new cli wrapper ?
jcohoe
Yes the latest supported code for 5508 is 8.5. The Ansible modules now work with both legacy and current SSH implementation.
I tried the same script on Ansible Tower but could not get the response and got the error message.
Attached the error message for your reference. Please suggest.
Leo Laohoo
Python scripts are available that will generate random characters.  Add a few lines to instruct the system to remote into the WLC to change the PSK (alternatively, can use SNMP to push the new PSK) and at the same time email you the new PSK.
Use crontab to schedule how often you want the script to run.
patoberli
There is also another way, requiring a RADIUS server, but could also maybe (ab)used for your requirement:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-5/b_Identity_PSK_Feature_Deployment_Guide.html
But honestly, it's easier with SNMP or SSH.
For SSH, try to send an empty username at first try, then the console should start and ask for the username, where you send the correct one. That would probably require a timed character sequence.
Ercuru
Community Member
Have used posh-ssh module for PowerShell for automation with New-SSHShellStream commandlet:
$ssh = New-SSHSession -ComputerName $IP -Credential (New-Object System.Management.Automation.PSCredential ($Username, (ConvertTo-SecureString -String $Password -AsPlainText -Force)))
$stream = New-SSHShellStream -SessionId $ssh.SessionId
Start-Sleep -Seconds 2
$stream.read()
$stream.WriteLine("$($Username)")
$stream.read()
$stream.WriteLine("$($Password)")
$stream.read()
$stream.WriteLine("config wlan disable <YOUR_WLAN_ID>")
$stream.read()
$stream.WriteLine("config wlan security wpa <YOUR_OPTIONS_FOR_PSK>")
$stream.read()
$stream.WriteLine("config wlan enable <YOUR_WLAN_ID>")
$stream.read()
$stream.WriteLine("save config")
$stream.read()
$stream.WriteLine("y")
$stream.read()
$stream.WriteLine("logout")
$stream.read()
$stream.Close()
Remove-SSHSession -SessionId $ssh.SessionId
$Username - variable with your login, $Password - variable with your login password, $IP - variable with remote controller IP
$stream.read - used for getting shell output back for logging
