Can I enable 40MHZ wide channels in PI for AC only on 3700 Access Points?
Georgia Coalman
Previously I have been able to enable 40MHz Wide channels on the AC module for 3600 access points as AC would be seen as a separate interface.
With a 3700 Access Point the AC module is integrated and hence the AC interface does not show up separately.
Is there a way to configure a 3700 access point in Prime for 40MHz wide channels for AC only?
PI Version: 2.2.0.0.158
8510 Controller running version 8.0.110.0
-Georgia
This is usually configured on your WLC - 802.11a > RRM > Dynamic Channel Assignment (DCA)
Rasika
*** Pls rate all useful responses ***
Thanks for your reply. I should have mentioned that I am not using RRM.
I am able to set 40MHz channel on the 3600 AC module. I can't seem to work out what to do with the 3700 as the AC module is built in and not presented as a separate interface.
