Can't change RF Channel Assignment and Tx Power Level
roberto.tyf
Just can't change radio parameters of RF Channel Assignment, Tx Power Level Assignment , all the option are grayed on  the 9800 WLC, within Configuration -> Wireless -> Access Point -> 2.4/5.0 ; is there a way change this? I just want to change de value of a TX Power from a global value to a custom  one and It's not been possible, is there a reason why? The ap model is C9120AXI-A.
Did you change the Assignment Method under Role Assignment from Auto to Client Serving?
 CJ
/**Please rate all useful responses**/
  Do you have enouth provilege on the WLC ?
Assignment Method should be available if you have enough privilege.
 CJ
That's right, it has to be on Client Serving to make changes. Thank you
