WLC5508
maged altwaiti
we have WLC 5508 S.W ver 7.6.110.0 . Field Recovery Image Version 7.6.95.16.
recently system is hung up and stop working and APs are disappeared. we can't do any thing  until we power off WLC and power on it .
Sys led is blinking amber and ALM ls is off.
we need to  your help us to solve  this problem.
regard<<<
6 Replies 6
balaji.bandi
check the below  thread may help to resolve the issue :  ( if you have contract raise an TAC case)
https://community.cisco.com/t5/wireless/wlc-5508-sys-led-blinking-amber-alm-continuous-on-amber-power/td-p/4151385
Also worth another look of the bug :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuc60927
BB
jagan.chowdam
It seems your controller crashed. Have a look at the "Checking the Controller LEDs" table from the following URL
https://www.cisco.com/c/en/us/td/docs/wireless/controller/5500/install/guide/ctrl5500.html#pgfId-35245
There is a crash file that is stored and can be exported. This is what TAC will ask for if you open a case.
Search for WLC crash file or WLC crash log:
https://supportforums.cisco.com/t5/wireless-mobility-documents/how-to-find-amp-retrieve-wlc-s-crash-coredump-from-its-s-flash/ta-p/3145554
CJ
/** Please rate useful responses **/
Haydn Andrews
Any reason your still running 7.6? I guarantee any Cisco support cases going to say its EOL and to upgrade.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
I suspect the lack of a valid Service Contract to download the firmware (WLC 55088 Upgrade).
Had maged altwaiti confirmed this is the case, I could have offered an option to download the firmware (legally, of course) for free.
Hello,,,
Thank you for help ...
our Service Contract is out of date .
could you please  download the firmware.
Regards,,,
Ok, here are the steps that YOU (not I) need to do:
  1. Read the Release Notes (for 8.5.X.X) very carefully.
  2. You will need TWO (2) firmware:  8.2.16X.X (or 8.3.X.X) and the destination firmware.  Take down the filenames of both firmware.
  3. Read this:  Cisco IOS XE Software for Catalyst 9800 Series and Cisco AireOS Software for Cisco WLC Flexible NetFlow Version 9 Denial of Service Vulnerability
  4. Scroll down to the Customers Without Service Contracts section.  Read that very, very carefully.
  5. Explain to TAC that you will need both firmware files.
Hope this helps & good luck.
