Can't enable 5GHz Radio on AP AIR-AP2702I-UXK9, and extreme low speed on 802.11n radio
quevedo_lopez
I can't enable the 5Ghz radio on the AP AIR-AP2702I-UXK9, can't configure on root, can i change the -UX domain to another where i can use the 5GHz radio ?  Also i'm getting a extreme low speed performance on 802.11ng clients.
ap(config-if)#station-role root
 Error: Station role can be only scanner mode on 5G of universal AP in -UX domain
Thanks advanced.
Rasika Nayanajith
First you have to prime this AP to country where you are in. Refer below for that
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ux-ap/guide/uxap-mobapp-g.html
Then only you can enable 5GHz on it.
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
quevedo_lopez
Thank you very much.
