WLC 2504 - Ap join fails with "Unknown AP type. Using Controller Version!!!"
I haven't encountered this problem before. On my WLC 2504 I've tried now software versions 8.0.100.0, 7.6.130.0 and 7.4.121.0 (as per recommendation from other supportforum-posts), but still get this debug error when I'm trying to join ap models 1142 and 2602:
(Cisco Controller) >debug capwap errors enable
(Cisco Controller) >*spamApTask5: Jan 02 02:11:46.549: Unknown AP type. Using Controller Version!!!
*spamApTask0: Jan 02 02:11:46.550: 88:43:e1:78:10:08 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 5,joined Aps =0
*spamApTask5: Jan 02 02:11:56.670: f8:66:f2:14:4e:c1 Deleting AP 10.68.254.101 which has not been plumbed
*spamApTask5: Jan 02 02:11:56.673: f8:66:f2:14:4e:c1 DTLS connection was closed
Does anyone know what is failing here? Surely the ap's should be "known" in these software versions?
Best
Bent Eskil
Scott Fella
Make sure the time is set properly on the WLC and also make sure the country code for the APs are set on the WLC.
-Scott
-Scott
13 Replies 13
Scott Fella
-Scott
-Scott
Setting the correct time was it. Embarrassing to overlook this on my part. Thanks for a very quick reply!
No problem, glad to help.
-Scott
-Scott
I have the same issue ,  but unfortunately fixing the time did not help.
Unknown AP type. Using Controller Version AIR-AP2802E-E-K9
My WLC is 5508 ,  System info :
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.135.0
The LAP is getting an IP but not joing the WLC .  I am using the internal DHCP with the management IP interface as DHCP.
Below is the CAPWAP debug output.
sco Controller) >*spamApTask5: Apr 12 19:16:43.992: 2c:5a:0f:1a:6c:e0 Discovery Request from 10.32.1.101:5272
*spamApTask5: Apr 12 19:16:43.992: 2c:5a:0f:1a:6c:e0 ApModel: AIR-AP2802E-E-K9
*spamApTask5: Apr 12 19:16:43.993: 2c:5a:0f:1a:6c:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 12, joined Aps =0
*spamApTask5: Apr 12 19:16:43.993: apModel: AIR-AP2802E-E-K9
*spamApTask5: Apr 12 19:16:43.993: apType = 46 apModel: AIR-AP2802E-E-K9
*spamApTask5: Apr 12 19:16:43.993: Unknown AP type. Using Controller Version!!!
*spamApTask5: Apr 12 19:16:43.993: 2c:5a:0f:1a:6c:e0 Discovery Response sent to 10.32.1.101 port 5272
*spamApTask5: Apr 12 19:16:43.993: 2c:5a:0f:1a:6c:e0 Discovery Response sent to 10.32.1.101:5272
Based on the Compatibility Matrix I think you need to upgrade the code on your WLC to support the 2802E. You have also have an E regulatory domain AP which means your AP is designed to be used in one of the countries below.
E Algeria Austria Bahrain Belgium Bosia & Herzegovina Bulgaria
  Croatia Czech Republic Denmark Estonia Finland France
  Germany Ghana Gibraltar Greece Hungary Iceland
  Iraq Ireland Italy Jamaica Kenya Latvia
  Lebanon Libya Lichtenstein Lithuania Luxemborg Malta
  Monaco Mongolia Montenegro Netherlands Nigeria Norway
  Oman poland Portugal Romania Russian Federation Saudi Arabia
  Serbia Slovakia Slovenia South Africa Spain Sri Lanka
  Sweden Switzerland Thailand Tunisia Turkey Ukraine
  United Arab Emirates United Kingdom Vietnam
8.0.140.0
15.3(3)JA10/
12.4(25e)JAP10
Lightweight APs: 1040, 1130, 1140, 1240, 1250, 1260, 1600, 1700, 2600, 2700, 3500e, 3500i, 3500p, 3600e, 3600i, 3600p, 3702e, 3702i, 3702p, 600 OEAP, 700, 700W, AP801, and AP802
Note Cisco MSE Release 8.0.140.0 includes wIPS support for the Cisco Aironet 1800, 2800, and 3800 series. However, CAS is not supported for these APs.
Outdoor and Industrial APs: 1522, 1524PS, 1524SB, 1532E, 1532I, 1552E, 1552H, 1552I, 1552C, 1552EU, 1552CU, 1552S, 1570, and IW3702
Note The Cisco Wireless Release 8.0.135.0 is a repost of the Cisco Wireless Release 8.0.132.0 and 8.0.133.0. This release impacts only the Cisco Aironet 1570 Series APs with -B regulatory domain and meet the following criteria:
a. The Cisco 1570 APs that are made available on or after June 2, 2016, for the USA region
b. The Cisco 1570 APs that are identified with version ID 02 (V02)
This release ensures that Cisco 1570 APs that are made available to customers in the USA are in compliance with the new FCC rules that come into effect on June 2, 2016.
8.0.135.0
15.3(3)JA9/
12.4(25e)JAP9
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-147162
http://www.wificert.org/regulatory-domains/
William Kuczmera
I have upgraded the WLC to 8.2.110.0 , but still having the same issue.
Do I need to configure anything on the APs ?
Hi, looks like I have the problem also.
WLC-5520 8.2.151.0 With regulatory Domain DE and apModel AIR-AP2802I-E-K9.
Until now I do not know what the problem is. Time is in synch and MIC authorization is enabled.
any suggestions ?
Zohaib Khan
Hi I have the same issue, today i rebooted the controller after that no Access Point is joining the controller.  While debug i can see same logs as given above. I have configured option 43 and 60 as well on cisco switch. Pool commands are:
ip dhcp pool Room-1
 host 192.168.30.113 255.255.255.0
 client-identifier 0188.1dfc.f7cb.30
 default-router 192.168.30.3
 domain-name mina.local
 option 43 hex f108.aca8.1e68
 dns-server 192.168.30.1 4.2.2.2
 option 60 ascii "Cisco AP c3702
I have checked the time and country code all fine but still Access point are not joining. Can you help me out to figure out the issue.
What code is your controller on ?
Thanks for response, i am running Software Version 8.0.110.0 on controller
If you just rebooted the WLC and nothing was changed, then that's not normal. All access points were up and running and the code wasn't uograded correct?
-Scott
-Scott
Thanks for response. Yes all the APs  were running and now I am getting this massage. The code was update 20 days ago. Everything was working fine but now I am facing this issue.. what I can do to resolve
Hi All,
These settingwork for me:
  • from GUI > Security > AP Policies > SSC and MIC certificates are checked
  • from GUI > Controller tab > Advanced > Master Controller option is enabled
But i don't got the point, i never use to check this even all other controllers they don't have these settings. Can anyone explain whether it is necessary. I have one more controller in LAN should i change for that as well.
