05-31-2019 03:52 AM - edited 07-05-2021 10:29 AM
I am wondering why this is happening. After the reset my AP's LED keeps cycling between red green and amber. so i cant configure through web ui. I performed the reset with the mode button and held it down for less then 20 seconds during boot.
Solved! Go to Solution.
05-31-2019 07:54 AM
05-31-2019 07:09 AM
This could also mean that you aren't supplying enough power.
Which model of AP and how is it powered?
05-31-2019 07:19 AM
05-31-2019 07:54 AM
05-31-2019 08:11 AM - edited 06-01-2019 03:00 AM
thnx for the help!
got it to work now with the longer rest.
