Cannot access http through wireless; through wired it works
mohamedrishin
Level 3
Level 3
Hi All,
I am having an issue with Cisco Aironet 1140 where I am able to access https sites as well as ping all the sites but cannot open http sites. Through wired connection everything works fine. I am attaching the config
Any help much appreciated. This is a new installation
THanks,
5 Replies 5
Surendra BG
To be frank AP has nothing to do with accessing the HTTP or HTTPS sites.. check for ACLs on the router, which may be blocking the access to secure server.
Surendra
Surendra BG
Thanks for the reply.
But with wired connection I can access the sites
Only ACL in the router is access-list 1 permit 192.168.5.0 0.0.0.255
Mohamed
use wireshark and capture the packets and see where the HTTPS packets are getting dropped!!
Surendra
Surendra BG
Its http packets getting dropped not https.
Mohamed
Wat ever!! it was a typo and sorry for that.. but something is getting dropped and we need to check that, either u know whats is getting dropped or me
Surendra
Surendra BG
