Cannot connect to 3702E AP using IP and browser
johnbouman
Hi, I just bought the Cisco 3702e AP and I am unable to connect to it using IE and it's IP address. I can Ping the IP and I can Telnet into it but I am not any good at using the Command Line Interface. I am trying to replace my current Cisco AP1024N AP with the faster 3702E AP, I can connect to the AP1024N using IE and the IP address without any problem. Can anyone assist me with this?
Thanks, the link does not address the 3702E AP, I need to be able to operate this AP in Autonomous mode, it is currently looking to find a "CAPWAP" server so I think it is running as LWAPP?
You are correct, you have a lightweight AP.
Can use this process to switch to autonomous mode? https://www.youtube.com/watch?v=T8T__dkg7P4  , if so, I need to find out if there is firmware available for the CAP3702E to run in the autonomous mode.
I just found this as well, apparently the firmware is available for download, (with a current support agreement in place).
https://supportforums.cisco.com/discussion/12153196/access-point-doing-80211ac-autonomous-mode
